http://gpsdump.no/body_gpsdump.htm
Цитата: Latest version
Version 4.92 (exe) (zip). Online validation of igc files. |
CyberKexx
23 Янв 2017
http://www.fai.org/gliding/gnss/tech_spec_gnss.pdf
Цитата: 3.2 G RECORD - SECURITY. The G Record verifies that the data has not been altered during or following
the flight. The FR manufacturer must provide a VALI program (see para 2.9.3.4 in the main body of this document) to check the integrity of the file with the security code. The security code must be generated by the FR, not by the computer extracting the flight data. Flight analysis software from sources other than the manufacturer should ignore the detailed data in this record, but can use the G record as a marker for the position of other data and records in the IGC file. All records must be included in the security mechanism, except the H records which have the O or P source, and any L records which do not have the Manufacturer ID (because some L records may be put in by the pilot). Format of G Record: G S S S S S S S S S S S S S S S S S S S S S S S S S S S S S CR LF G S S S S S S S S S S S S S S S S S S S S S S S S S S S S S CR LF G S S S S S S S S S S S S S S S S S S S S S S S S S S S S S CR LF G S S S S S S S S S S S S S S S S S S S S S S S S S S S S S CR LF G S S S S S S S S S S S S S S S S S S S S S S S S S S S S S CR LF G S S S S S S S S S S S S S S S S S S S S S S S S S S S S S CR LF etc G record - Description Size Element Remarks Security code Up to 75 bytes per line SSSSS Как я понял, то, как по треку строится G-код, каждый производитель решает сам, и его задача предоставить в FAI софт, который проверит соответствии трека и контрольную сумму. Но не факт, что он эту информацию обязан доносить до всех желающих (в т.ч. авторов GPSDump), иначе желающие напишут программу, подделывающую эту подпись. |
CyberKexx
23 Янв 2017
Видимо, нужно узнавать у производителя прибора, с которого скачан трек, как трек можно валидировать. В идеале, у них должна быть формочка: ты им файл отправляешь, а они тебе ответ - валидный или нет.
CyberKexx
23 Янв 2017
А вообще, странно, что не стандартизовали это дело. Можно было бы считать какой-нибудь хэш по данным координат, и шифровать его несимметричным шифром. Тогда производители бы могли давать всем публичные ключи для проверки, а приватные ключи хранить в приборе, причём отдельно от кода прошивки.
Выводы.
Истинность файлов формата IGC могут проверить только производители этих приборов или программ. В настоящее время программа GPSDump не проверяет эти файлы на истинность. Существует ряд производителей и их приборов, истинность файлов которых, можно проверить средствами ФАИ. Если вы собираетесь представить такой файл в ФАИ, то скорее всего от Вас потребуют возможности его проверки. Скажу кратко: я ни у кого таких приборов не видел. Список производителей ниже катинка |
