Форумы paraplan.ru Снаряжение GIN Concertina Compress Bag
DL
профиль
28 Дек, 11:56
200 грамм счастья! Размеры 2.7 и 3.0 м.
Редактировалось: DL (28 Дек, 12:03), всего редактировалось 1 раз
DL
профиль
28 Дек, 12:53
Re: GIN Concertina Compress Bag
Advance Omega X-Alps 24 & GIN Concertina Compress Bag.
DL
профиль
21 Фев, 15:53
Обзор IN Concertina Compress Bag от Flybubble Paragliding.
Оригинал - https://flybubble.com/blog/gin-concertina-compress-bag-review
by Carlo Borsattino on February 21st, 2018 at 12:00 pm 0 Comments
Categories: Accessories Reviews
Gin Concertina Compress Bag reviewer
Packing using a concertina bag helps to preserve your paraglider by protecting it from moisture and mud when packing, and keeping the leading edge section neatly folded. Although Gin produce two sizes of the Concertina Compress Bag (2.7m and 3.0m) both are aimed at lightweight wings (which have a small pack volume).
Like many concertina bags, you can leave your glider attached to your harness, and pack from a bunched configuration. It’s best to butt the concertina bag up against the wing and stretch both flat, then gather the wing at the leading edge. Because of the unique folding system, try to interleave the leading edge ribs, one or two ribs at a time. When all the cells have been gathered up, secure them with the buckle closure.
Image thanks to Timm Asprion
Then gather the trailing edge ribs and work your way towards the leading edge, clipping the bag closed and pushing out the air as you progress. I prefer the clips to a zip; I find them easier to manage.
When the wing looks like a ‘sausage’, you fold it in half then half again, at which point the short zip reveals itself to close the folded wing tightly in the compression bag.
This creates a small, flat package which packs very well in a paraglider rucksack, giving some stiffness to the pack while being very compact.
Gin Concertina Compress Bag review: up close
I’d like to see a version for normal ‘full fat’ paragliders, as I think this design is innovative and extremely useful.
If you currently fly a lightweight/semi-light wing, I highly recommend the Gin Concertina Compress Bag. Being so lightweight (200grams!) it weighs little more than a standard stuffbag, and it certainly makes a great travel companion.
Find out more about the Gin CONCERTINA COMPRESS BAG
CONCERTINA COMPRESS BAG: VIDEO REVIEW
Coming soon
макс68
профиль
21 Мар, 14:38
получил в подарок пользуюсь. штука классная. единственное я думаю для легких крыльев. В 2,7 м вмещается отлично джин эксплоер максимального размера.
DL
профиль
21 Мар, 15:44
Можно сказать что для него и создавалась
