“ Strive for continuous improvement, instead of perfection” – Kim Collins
We believe that Collins’ quotation reflects a lot of the innate Vittorazi Motors’ attitude aiming to meet the growing customers’ expectations in terms of flying performance, quality and safety. This company approach, has recently allowed some significant design improvements in the Moster Family such as a more performing belt, an innovative muffler and a new reduction cap.
The new belt, developed with the close partnership of the German Optibelt company, is made of high and long-lasting quality rubber which provides an improved motor flying performance with a longer engine availability and an increased reliability. This new product, initially implemented on the Moster 185 Factory will be customized with the Vittorazi logo and released on the market in the next weeks.
In addition to the belt, a new muffler with ceramic painting has been recently installed in all Moster Family engines. What will it change over the previous muffler ? The main difference will consist of a new high quality paint that will be more stable and suitable for the most extreme work conditions and temperature (over 1800 °F /over 1000°C). From Company point of view the new muffler represents the most appropriate response to the pilots’ demand across the world.
Last but not the least, it is worth mentioning the new reduction-cap implemented in the Moster185 Factory and Moster185 Plus. Thanks to this implementation the cap will be able to collect inside the pinion any leak of grease and at the same time prevent any possible contamination from dusts and sands that may cause potential loss of reliability of the bearing system longevity. With this new functional and well-designed reduction-cap, Vittorazi Motors believes to have added a “touch of class” making its motors safer and even much more charming.
«Стремитесь к постоянному совершенствованию, а не к совершенству» - Ким Коллинз
Мы считаем, что цитата Коллинза отражает многие из присущих Vittorazi Motors качеств, направленных на удовлетворение растущих ожиданий клиентов в плане летных характеристик, качества и безопасности. Этот подход компании недавно привел некоторым существенным улучшениям в дизайне семейства Мостеров, таких как более производительный ремень, инновационный глушитель и новая заглушка ведущего шкива.
Новый ремень, разработанный в тесном сотрудничестве с немецкой компанией Optibelt, изготовлен из высококачественного и долговечного каучука, который обеспечивает улучшенную работу двигателя при увеличении ресурса и повышении надежности. Этот новый продукт, первоначально реализованный на Moster 185 Factory, будет выполнен с логотипом Vittorazi и поступит в продажу в течение нескольких следующих недель.
В дополнение к ремню, недавно был установлен новый глушитель с керамической покраской на всех двигателях семейства Moster. Что изменится по сравнению с предыдущим глушителем? Основное отличие состоит в новой высококачественной краске, которая будет более стабильной и пригодной для самых экстремальных условий работы и температуры (свыше 1800 ° F / 1000 ° C). Это наш ответ на просьбы пилотов по всему миру.
И последнее, но не менее важное: стоит упомянуть о новой заглушке ведущего шкива, реализованной на Moster185 Factory и Moster185 Plus. Благодаря применению этой заглушки будет предотвращена любая утечка смазки и в то же время будет возможно предотвратить возможное загрязнение от пыли и песка, что может привести к потенциальной потере надежности долговечности подшипниковой системы. Благодаря этой новой функциональной и хорошо продуманной заглушке Vittorazi Motors считает, что сделала моторы более безопасными и даже более очаровательными.
